A widescreen 15.4" notebook computer by Compaq released May 2006.
4вопросов Показать все
computer doesn't start up
It wont start up. Only see a blinking cursor on a black screen. By pressing F10 while booting up I enter the setup. Here I see for the diagnose the options for selftest harddrive. Everything seems ok. I try to reinstall the windows xp by cd. The cd starts up but then the computer says there is no harddrive. What can go wrong?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
De Cuyper, sounds like a bad hard drive to me. Try to see if the hard drive shows up in the BIOS. Make sure it is properly connected. Most likely so you will need a new hard drive.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
In the bios I can check if there should be a problem with my HD. This seems to be ok. But when trying to install the windows XP the computer sais there is no HD. I connected the hd extern and I can see the HD is ok.
из
Добавьте свой ответ
De Cuyper будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 414
