Where is fuel pump located and diagram to replace old fuel pump
2001 Doge Dakota quad cab 4x4 fuel pump going out
Это хороший вопрос?
Это хороший вопрос?
Your fuel pump is inside the gas tank. You will either have to take the bolts out of the bed and jack it up on the drivers side. Or you can take the two straps loose from the tank, and unbolt the screws from inside the gas lid. And ease the tank down. You would also have to jack up the left rear of the truck to get it out. Hope this helps.
Был ли этот ответ полезен?
Can you also cut whole in the bed of the truck to get access to the fuel pump
За последние 24часов: 2
За последние 7 дней: 19
За последние 30 дней: 65
За всё время: 2,879
