This Kodak camera model was released in August 2009. It comes in a variety of colors, and the device allows you to view your photos on a three inch color LCD.
3вопросов Показать все
Why will my battery not charge?
I have plugged in the camera and left in on the charger for a few hours. However, the charging light will not come in while its plugged in, and the camera will still not power on after being plugged into the wall after a few hours.
Это хороший вопрос?
Оценка 2
1 Комментарий
where can I buy a new battery for my Kodak Easy Share 2730 camera
из
Добавить комментарий
2 Ответов
Выбранное решение
Make sure that you have properly installed the battery and that it is clean making for good conductivity. The battery might also be dysfunctional, requiring you to have to replace the battery. Your charger may be damaged or be the wrong type of charger causing it not to function properly. Assess which of these might be the issue and pursue remedial action. You may have to buy a new charger or simply have mixed it up with another one you might have. Another common issue is not with the camera system itself but with the outlet you plug it into. Try another outlet to see if it is a dysfunctional outlet and not the battery or charging cords that is the issue. For further information refer to the following links:
Kodak Easyshare M381 Troubleshooting
Был ли этот ответ полезен?
Оценка 7
3 Комментариев:
I have tried two chargers, but neither one charges the battery. Does it possibly need new battery? thank you
из
I have this problem but the battery is absolutely new. Only bought the camera this morning but the charging light won't come on at all.
из
I have the same problem, camera has only been used once since new.
из
I had this problem until I used 2 Duracell Batteries, 14 year old Kodak Camera works fine now
Оценка 0
Добавьте свой ответ
Christina Hamby будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 31
За последние 30 дней: 134
За всё время: 12,243
