Отремонтируйте ваше устройство
Обучение ремонту
Магазин
The Kindle Touch (D01200) is 4th generation of Kindle e-readers produced by Amazon. There is Wi-Fi or Wi-Fi/3G capability, all uploads are done by USB cable. It has 4 GB of storage and two months of battery life.
26вопросов Показать все
Why did my WiFi suddenly stop functioning?
I dropped my Kindle recently and it has a hard time trying to receive a WiFi signal while trying to connect to the internet.
Это хороший вопрос?
Оценка 0
Добавить комментарий
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
1 ответ
When you dropped it, you might have disconnected the WiFi antenna cable. You will have to open the casing to reveal the entire motherboard and on the rear side top left corner, there should be a black antenna cable that is unplugged. Just plug it back in by pushing it down into the port. If that is not the case, then you will have to replace the whole motherboard. Check with the Kindle Touch troubleshooting guide for options.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jerome Narine будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 111
