This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25вопросов Показать все
Axis show on screen when touch shows where the X&Y axis meet.
The problem is that at the top of the screen it shows the following:P:0/1 dX:0.0 dY:0.0 Xv:0.0 Yv:0.0 Prs:0.21 size:0.19 . Also when you touch your screen two lines appear showing where they meet . When you swipe it draws all the points if meets in the x&y axis.. How to repair this problem ?
Это хороший вопрос?
Оценка 3
1 Комментарий
See Muthu's 2 similar answers below.
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Simple Solution
Go to Settings - System Setting - Developer Option - select off
Pointer will be close
Thanks & Regards
M.Muthu
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
My settings menu is not straightforward, and file transfer requires the developer menu, but turning Developer Option off made the "feature" go away. Now I can stop uninstalling suspect programs. Thanks!
из
The digitizer touch display can be enabled or disabled using developer mode.
Оценка 1
It seems like it is running in a test mode for tracking the digitizer. Turn off your tablet and then turn it on holding the power button and the volume up button. This should open the boot menu and give you the options of loading the tablet in "Recovery," "Fastboot," and "Normal."
The Recovery menu allows data backups and factory swipes. A factory reset may fix it, but it will also erase everything on your tablet. If you have a data backup, that may be another option to try and fix the problem.
Fastbook allows you to access the internal memory via and flash new image files via PC. Reflashing your image will reset the tablet to factory, as well, but it will allow you to use custom firmwares.
Normal is the normal load. Not much hiding in the name. Maybe you just need to select this option to get it up and running.
Try the different options and post your results. I want to know what happens!
Оценка 0
Simple solution
Connect your handset to PC#
Go to USB dubbing connected#
Go to devolper option#
Click on pointer location to off#
Pointer will be close with axis.
Thanks
Bairagi g.r.
Оценка 0
2 Комментариев:
Thank you so much sir..
из
Fixed my issue. Thanks.
из
go to settings, find developer options, scroll down till you find ‘show pointer location.’ select off , problem solve.
Оценка 0
1 Комментарий:
I do not have a Developer option tab, where else can I find that. Using a Galaxy Tab A.
из
Добавьте свой ответ
Manuel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 51
За всё время: 6,168
