Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
86вопросов Показать все
Idle high, Overheating occurs quickly
1994 honda accord coupe had water pump replaced. Idling is high. Overheating occurs quickly. Cant figure out where the water is coming out of. Should radiator be replaced?
Это хороший вопрос?
Оценка 1
2 Комментариев
Is the water leaking? Checked the thermostat? what else did you check? do your fans come on?
из
Water is leaking. Fans come on. Thermostat was replaced. But there is water leaking from a area underneath the radiator.
из
Добавить комментарий
1 ответ
Выбранное решение
Tina, check your radiator hoses to make sure they are properly clamped and that the hoses are okay. If so, it is possible that your radiator is leaking. Any shop should be able to do a pressure test to see exactly where it leaks. Yes, there is a distinct possibility that you may have to replace the radiator.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Tina будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 1,159
