The 2008-2014 (fifth generation) Honda City was unveiled in Bangkok, Thailand in September 2008. In South Africa, the Honda City is called the Honda Ballade.
19вопросов Показать все
How to update 2014 Honda City's Infotainment system for CarPlay?
I have a 2014 HONDA City. One of the I/O interfaces is an HDMI port. This allows some apps to run on the screen (E.g. Waze, AppRadio etc).
How can I update the Infotainment System for compatibility with CarPlay?
Is there a way to get the full CarPlay functionality?
How can I update my infotainment system to a newer version?
The issue is that I am currently living in UAE, and the dealerships/service providers do not know anything about CarPlay, let alone help me with this question.
Это хороший вопрос?
Оценка 5
2 Комментариев
This question was migrated from http://meta.ifixit.com/Answers.
из
need solfware update
из
Добавить комментарий
3 Ответов
Выбранное решение
After a long search, it turns out that this system can’t simply be updated via software to include CarPlay or Android Auto.
However I found an alternative which is decent, but not perfect.
https://www.navtool.com/carplay.aspx
I’m not sure if there are other systems like this out there, and I have also yet to try this personally. But it’s a good workaround if you want to try it yourself.
(got this solution thanks to Reddit)
Был ли этот ответ полезен?
Оценка 0
Honda says its a new system and you can not update. Is that true.
Оценка 0
1 Комментарий:
Yes, unfortunately, I believe this is the case.
из
There's also https://www.mergescreens.com/collections... ++++
as another possible solution, though I don't have much information about it.
Remember to research and check reviews before making a decision.
Оценка 0
Добавьте свой ответ
Tanuj будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 17
За последние 30 дней: 74
За всё время: 7,623
