Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328вопросов Показать все
How long is a new battery's shelf life?
The battery in my 2011 Macbook Air began raising a "replace immediately" alert after 2.5 years of age. I ordered a new one, and waited for the old battery's charge to degrade, but it never did. That was over a year ago. It can still last for about two hours on a full charge. In the meantime, the ifixit battery I bought is still sitting on the shelf in its shipping box. While I continue to wait, is there any danger of the new battery getting "stale" and not working well when I finally do swap it in?
Это хороший вопрос?
Оценка 3
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hello,
from my experience the degradation of a battery life depends on the discharge/charging cycles. So if you leave the battery in its package on the shelf for a long time the chemical reactivity of the single battery cells should remain at a very high level. Although the battery could loose some voltage after some time.
Был ли этот ответ полезен?
Оценка 1
I've exactly the same question, but my MBP 2009 Model still holds a charge of 2-3 hours. I've got a new battery sitting in my shelf since OS X keeps telling me to replace it, but I don't want to replace it until the old one inside the MBP has been completely used out.
Did you find any answer to your question?
Оценка 0
Добавьте свой ответ
johnsgchurchill будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 857
