The Lenovo A7 tablet is a 7-inch Android tablet released by Lenovo in April 2015. The A7-30 tablet was released in two versions, the 3G/Wi-Fi model (MediaTek MT8382M) version, and the Wi-Fi only (MediaTek MT8127) version.
33вопросов Показать все
Why won't my Lenovo A7-40 power on?
it was fully charged n it just stopped working and wont on
its been 3 days and it wont get on i tried charging it but it wont get charged
Это хороший вопрос?
Оценка 13
3 Комментариев
I have a tablet and it turns on and you can hear everything but you can't see anything
из
I have this problem
из
my lenovo won t open
из
Добавить комментарий
6 Ответов
Наиболее полезный ответ
If it does turn on it pops up Reboot and some other stuff too
Был ли этот ответ полезен?
Оценка 1
lenovo tab not turning on
Оценка 1
Guys Just press reset button and then press power button..if you cant find the reset button just open the back cover en then you can press it with finger... Good luck
Оценка 1
Check the battery. I opened mine and the battery didn´t charge anymore
Оценка 1
I had such a problem
The battery just had been moved
I put it right and labeled it
It worked
Оценка 0
If you can feel the motor is buzzing, try to check the lcd cable, many lcd cable faulty in this device, that`s my experience, or try to disconnect and put it back. If it`s not charging can be charging port issue or battery even motherboard. try to factory reset with the power button and the volume up button.
Оценка 0
Добавьте свой ответ
sandy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 3,328
