Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
The third iteration of the 10.1 inch Galaxy Tab tablet.
127вопросов Показать все
Why is my screen discoloured?
I went out for a bit came back and went to go see my tablet to realize the screen is discoloured like a fuzzy pink color and it looks like the screen is spazing but it's not please help I can't watch or do anything because my screen blurs out most of everything with pink I'm guessING it was because to much pressure put on it but I dont know please help!!!!
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 5
Комментарии:
How did you end up fixing it? I just woke up and mine is doing the same thing
из
The same way unscrew the back part
из
mine ended up turning black and i dont know what i should do
из
Добавить комментарий
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Ответов
Выбранное решение
Theres only one solution n its to take off the back cover n theres 3 cables going over the battery disconnect the far right one with the green strip of tape an reconnect an start ur tablet n it should be good....
Был ли этот ответ полезен?
Оценка 11
Комментарии:
After searching the internet for weeks for a solution to this problem following your instructions worked.
I love you!
Months without a tablet have come to an end!!!
из
THANK YOU, THANK YOU, THANK YOU.
Simple fix and it worked!
-RJR
из
Just tried the fix....worked like a charm!! back up and running! no pink stink
из
It worked!!! Thank you so so much! You saved me a bunch of money ☺️ Also I used this site which has an image step by step guide that I found useful along with this info
https://www.sosav.com/guides/tablets/sam...
из
Hi I have the same pink fog on my Samsung J7 mobile. It's the model 2016 that you cannot take the back off. Any answers pleeeeeease. Thank you.
из
Holy $@$* it worked, mine had a green tint or hue to the screen. unplug the battery connector, wait a minute and plug back in.
Оценка 1
Комментарии:
Didn't work for me...thick blue band visible towards left from the centre of the screen...
из
Добавьте свой ответ
calliemoore16 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 60
За последние 30 дней: 351
За всё время: 13,143
