Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
452вопросов Показать все
"unfortunately Lenovo Launcher has stopped working"
My A3300 tablet was put on charging. it showed "lenovo launcher has stopped working" and then it turned off.now it does not turn on. please help!!
Это хороший вопрос?
Оценка 24
17 Комментариев:
Thank you for your work
из
I am also faceing same problem
из
My mob k3 note I face same problem
из
Kindly help me how to solve my hp problem..
'lenovo launcher is not responding'
i have tried many times to restart my hp but end up my hp still can't function normally.
из
i have the same problem. I tried to disable some of the apps to free some spaces for the RAM to work faster. Then, this shows on my screen (Lenovo Tab2 A7-30) "Unfortunately lenovo launcher had stop" ....everytime i tap OK, it comes pops up again. I tried to reboot my lenovo tab, then on the box for the password, my keyboard isn't appearing anymore so i cannot key in my password (combination of letters and numbers). What should i do now? Please help me.
Thank you very much in advance!!
из
Показать 12 больше комментариев
Добавить комментарий
5 Ответов
Assuming this is an android tablet.... I would say that your software has been corrupted. Try doing a hard reset here:
http://support.lenovo.com/us/en/videos/v...
Hopefully this helps you out! Let me know if it doesn't work for you.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
My Lenovo Tab 2 A7-30 has the same problem of "unfortunately lenovo launcher had stop" maybe this is because i tried to disable some of the apps to free some space for the RAM to work faster.....do i need to tried ur link above sir? PLEASE HELP ME.
Thank you in advance.
из
Check this video this will resolve this issue. I resolved by following this video only
https://www.youtube.com/watch?v=3yAer-MN...
Оценка 0
1- open setting and open apps option
2- open all running apps
3- search lenevo launcher and clear the data and launch again
4- reboot your device
5 - follow this step i think your problem may be fixed up.
THANKU
Оценка 0
1 Комментарий:
It is impossible to get into the tablet with this failure!
из
Go To settings-->Apps-->ALL-->Lenovo Launcher-->clear data
Оценка 0
3-open -Disabled menu
4 - enable theme app
Оценка 0
Добавьте свой ответ
saket jha будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 13
За последние 30 дней: 70
За всё время: 34,677
