This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316вопросов Показать все
Won't power on, greenlight comes on momentarily.
Nintendo ds lite, won't power on. When you hit the power button the green light comes on for a moment, then the bottom screen flashes and unit powers off. Top screen does nothing.
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
hi
this is basically because your top screen is faulty and needs to be replaced. You'll probably find that the ribbon of the top screen has kinked and torn over time.
The bottom screen still lights up because the ds sends power to both screens but then when it realizes, nothing is getting through to the top one, it switches itself off
hope that helps
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
sacredflowerbrian будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 2,167
