Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
3418вопросов Показать все
iPhone 5 cracked screen wont turn on
It worked for a year with the screen cracked for a long time then one day it wouldn't turn on at all.. If I replace the screen will it go back to working?
Thanks James
Jbrey411(at)Gmail.Com
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Plug the iPhone into iTunes and see if it's reconised when about 30 minutes incase the iPhone is out of charge and let iTunes charge it..
I won't get reconised if it's out of charge it needs to boot up..
If it's reconised then it's most likely a damaged screen and a new one will fix it
Был ли этот ответ полезен?
Оценка 2
Hi Jim Smith,
The problem could be anything,honestly. You would have to open the phone to inspect any possible damages. Could be the battery is not charged and your charger has broken, could be that the LCD has been cracked and you need to change the screen, could be a water damage causing a short circuit.
Оценка 0
I ha e the same problem and I don't have any money to fix my iPhone 5c and I really want to use it. Do u know anywhere anybody would do it for free? I know that's stupid to ask but I really want to use it
Оценка 0
my i phone 5c broke the top screen broke and it wont turn on would it worck if i get a new screan
Оценка 0
Комментарии:
my i phone 5c cracket the whole top part did would it worck if i get a new screen for it
из
Добавьте свой ответ
Jim Smith будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 7,012
