motor works but blades only spin if grinder is unloaded
The machine seems as if it's working with no load or with very small amount, but as soon as I put in a normal amount of material to be ground then the blades do not turn. It's like whatever connects the blades to the spinning shaft has failed or does not engage properly. Also how do I get the blades off?
Это хороший вопрос?
1 Комментарий
The blade screw is stripped. I have the same problem. I can’t find a replacement blade.
из Stephen
