iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
896вопросов Показать все
iPod syncs then ejects 10 seconds later
I've had my iPod classic for two years and needless to say she goes EVERYWHERE with me. I've had no problems with her until recently. I sync my iPod to itunes and then a few seconds later it will automatically go into ejecting. I've uninstalled and re-installed itunes,I have the lastest version.. I've even restored my iPod. Please help me I'm going insane !!!!
Это хороший вопрос?
Оценка 2
1 Комментарий
Have you started using an usb-hub lately?
из
Добавить комментарий
2 Ответов
Выбранное решение
i've read a few things. maybe this would help:
start itunes, go to "Edit" -> "Preferences" shwitch to the "Devices" tab. and toggle "check on and off" the disable automatic syncing feature, this should fix the problem.
but normally it would be enough to change the settings from automatic to manual on the "top page" for the iPod - i always use the manual sync on my iPods - the method above is more for the people who were plagued by a fast "3 second sync"
Был ли этот ответ полезен?
Оценка 5
1 Комментарий:
what if there is not a toggle option ?
из
I had the same connect/eject issue
The issue for me was that the ipod was almost out of power.
Once I charged it up using a wall charger it connected fine
This was after testing usb ports, swapping cables, etc....last resort was to power it up
Problem solved
Оценка 1
1 Комментарий:
из
Добавьте свой ответ
breakdown69s будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 56
За всё время: 19,881
