The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
24вопросов Показать все
Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
Это хороший вопрос?
Оценка 2
Комментарии:
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
Был ли этот ответ полезен?
Оценка 2
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
Оценка 1
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
Оценка 0
Комментарии:
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
из
Добавьте свой ответ
Ron Skelly будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 4,790
