Repair and disassembly guides for Acer Iconia Tab tablets.
How to fix shutdown of an acer iconia B1-730?
My acer iconia 7 B1-730 would not charge and turn on at all after randomly shutting down when its battery was at around 50%. Don't know why either the charger or the device itself, but still it won't turn on, is there anyway of fixing this?
Это хороший вопрос?
Счет 5
Добавить комментарий
1 ответ
Наиболее полезный ответ
You can go through the easy steps first, try a different cord, try a different brick. Most likely though your issue lies with the battery or the board. You can order a battery online if you are confident enough to change it out yourself, but if it's a board issue you'd be better off getting a new tablet rather than spending the money to fix that one.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Christian Balon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,919
