iMac Intel 24" (1st gen silver case) LCD Screen Replacement?
Hello,
I have been told that my LCD display on my iMac needs to be replaced. the bottom part of the screen is very dim. The quotes I have received are $700. Of course, therefore does not make sense to repair... Any suggestions on obtaining a relatively cheap replacement screen? Thanks!
Brian
Это хороший вопрос?
13 Комментариев
Is this a half screen issue? Very dark at the bottom and gradually getting lighter till it gets to the center? Please tell us what the diagnosis was and who gave it to you. This is the very issue that first brought me to this site and my first question so I am intensely interested in helping solve this issue.
из mayer
Hi Mayer,
Yes, EXACTLY what you describe is the problem. I have called two Apple repair centers and they have both told me that the screen needs to be replaced, and both indicated it was bulbs that have failed that backlight the screen. Any suggestions how you solved your problem would be appreciated. Thanks!
Brian
из Brian Caffarello
I don't have an answer. Here's my very first question: top half of screen is greyed out
из mayer
Hi Mayer,
Brian
из Brian Caffarello
Has anyone considered the following
make up some cables to allow the inverters to be swapped while insitu and powering up. That should at least tell you if it is inverter or CCLF failure
I have mine open ATT so I'll see if I can ID and source connectors to suit
FWIW I have a "dead" imac here and have ordered a new VGA if that does not fix it I'll have a go at opening up the LCD and getting at the CCFL tubes
из Richdave
Показать 8 больше комментариев
