Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75вопросов Показать все
Why wont my phone come on and blinks on and off
my samsung s5 active just shut off and wont come back on. but i can plug it in to charger and try to turn it on and it will display the welcome screen saying {samsung galaxy s5 active etc etc..} and continually blinking on and off..and if i push power button it will show the battery charging but it will also blink on and off
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Sounds like your phone isn't charging properly. You could get a new charging port installed, or possibly try buying a wall charger for it. Just be careful not to over charge the battery. Hope that helps.
Был ли этот ответ полезен?
Оценка 1
My active s5 will work if I don't touch the power button but will start a reboot loop once it gets down to around 35% and takes several attempts of removing the battery and once it's back up and going it does ok....if I don't touch the power button. Where do I find and replace a new power button?
Оценка 0
Добавьте свой ответ
nickiek1983 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 1,180
