Repair guides and support for phones manufactured by Lenovo.
My power button is not working lenovo a7000
I have charged my phone overnight.In the morning i came to see that my power button is not working.Help me out
lenovo a7000
Это хороший вопрос?
Оценка 15
3 Комментариев
lenovo a7000 switch solution
из
my phone was not getting charged more than 15% and now it cant be switched on? plz help
из
What to do if lenevo 480060a2 on off button is not working . And if mobile phone get switch off
из
Добавить комментарий
Ответов (7)
Наиболее полезный ответ
Был ли этот ответ полезен?
Оценка 3
I faccing same problem
help to out me from this problem
Оценка 1
2 Комментариев:
Facing same problem.
из
Turn on tap to wake from menu. that's how i bypassed the power button bullcrap.
из
1) Connect your phone to a computer using USB
2) Hold upper volume key for 5 seconds as soon as your phone is plugged in to a computer using USB cable.
3) A menu will appear. Use upper volume key and go to the 3rd option which is " boot normal"
4) Press lower volume key for selecting that option.
Your phone will be switched on automatically.
Оценка 1
Restart it just by adding the restart button in the notification panel when you slide down you'll see a 4 dot at the right side.
Оценка 0
I have lenovo a7000 I charge phone at night next day phone is not switch on what should I do
Оценка 0
Change Sleep option to ‘Never’ under settings, display option. Although this isnt a solution, may temporarily address the problem, at the cost of draining batter
Оценка 0
My power button was broken
Оценка 0
Добавьте свой ответ
arjnkar будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 14,411
