Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
490вопросов Показать все
Where is located the screen backlight fuse?
After a liquid spill, I've cleaned the motherboard and connexions. Everything worked fine for some time but the screen started to blink and went dark a few times until it got dark permanently.
Anyone can point me where the screen backlight fuse is located in the 13" retina mid 2014 model?
Это хороший вопрос?
Оценка 3
Добавить комментарий
2 Ответов
Выбранное решение
Roy Lopez, that would be F7700 which is a 3 A 32 V fuse in a 0603 package. This "screen started to blink and went dark a few times until it got dark permanently." does not sound like the fuse. You do want to check a bit more. Of course, check the fuse first.
Был ли этот ответ полезен?
Оценка 6
Pin 1 of LCD connector is probably &&^&@@.
Оценка 0
Добавьте свой ответ
Roy Lopez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 4,943
