Trying to use and external microphone.
The internal Mic in my Macbook is broken. When I install an external Mic, it is recognized in the sound panel, but the system doesn't receive any input from the mic and I've tried several.
Это хороший вопрос?
Это хороший вопрос?
I would make sure that under System Pref, Sound, Input and Line In are selected which is obvious you checked that. How are you attaching the microphone? Is it a USB mike, through a mixer via the XLR ports, does the mike require a 9 volt battery if you don't have a USB or FireWire interface with phantom power? Are you attaching the mike through the audio port via a 1/8 inch jack cable?
Post your specs and maybe someone here can figure out a solution to get the MacBook to recognise the mike.
steve
Был ли этот ответ полезен?
It's just a standard non power mic attached to the 1/8 audio in jack. I have three USB ports and with firwire and the headphone in/mic in ports.
People have suggested using a USB mic instead.
Thanks.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,261
