Engine siezed. Parked then wouldn't start
Engine won't start
Update
Took out starter Turned engine by hand. It won't turn.
Это хороший вопрос?
Engine won't start
Это хороший вопрос?
If you absolutely can not turn your engine over (remove the accessory belt and use a breaker bar with the appropriate socket on the crankshaft pulley) than you most likely have some severe engine damage. Not much you can do on a seized engine other than to replace it.
Был ли этот ответ полезен?
There is starter coil between battery and starter motor, try replacing this.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 197
