July 2013/ 1.0GHz ARM single core/ 4GB SSD/ 512MB RAM/ Android 4.2
12вопросов Показать все
Can you explain how to do factory reset
I put a child lock password n know I don't remember it. I am turning off the tablet by then holding the power off option then is asks about safe mode I say yes . It then says shutting down but when it restarts it is still locked
Это хороший вопрос?
Оценка 2
6 Комментариев
To do a factory reset, when the device is off, press and hold the power and volume up buttons at the same time and hold for at least 10 seconds.
из
my tablet is running real slow and keep cutting off.
из
How can I reset it if it doesn't have the volume buttons.
из
followed instructions still reading wrong pin. how do you reset. Polaroid is the worst company to ask for help. All tablets should be recalled. A real waste of money. HELP for POLAROID
is a BIG NO NO> impossible TO GET HELP ON INTERNET OR ON PHONE. BIG WASTE OF MONEY ON MODEL M11H/Q1100 BE VERY CAREFUL NOT TO FORGET PIN. YOU CAN NEVER RESET TABLET.
из
I can't factory reset my tablet, what do I do now.
из
Показать 1 больше комментариев
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Erase data using the Settings menu
To perform a factory data reset using the Settings menu, follow these steps:
Before you reset your Android One, see options for backing up your data.
On your mobile device, open the Settings menu Settings .
Under "Personal," touch Backup & reset. You may need to enter your pattern, PIN, or password.
Under "Personal data," touch Factory data reset.
Read the information on the screen and touch Reset phone.
If you have a screen lock, you'll need to enter your pattern, PIN, or password.
When prompted, touch Erase everything to erase all data from your device's internal storage.
When your device has finished erasing, select the option to reboot your device.
You'll see the Welcome screen just as you did when you turned the device on for the first time. When you're done with the
Был ли этот ответ полезен?
Оценка 1
this will not reset, you have to use Adb command or you can reflash it.
Оценка 0
3 Комментариев:
I just want to get this fix , so that I can use it.
из
is there a place to send it to get fix.
из
I only had this tablet for one year.
из
Como la uso con que le salga unfortunely, KIDO'Zhas stopped
Оценка 0
1 Комментарий:
Nunca e podido usarla
из
Добавьте свой ответ
Wendy Olivas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,471
