The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
115вопросов Показать все
warning light on my dashboard
got a warning light on my dashboard, orange light come on
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hello, without more detail it will be hard to be certain of the answer. However, there are only a few lights on the dash of these old cars.
If the warning light is orange and has a circle in the middle with dashed lines around it that is your front brake pad wear sensor. It most likely means that your front brake pads are worn and need to be serviced soon, perhaps along with other brake parts.
If the light is orange or red and says BRAKE that either means the car thinks your parking brake is still set, or it means you are low on brake fluid.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Sulayman будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,169
