Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
4069вопросов Показать все
Some problems after Battery replace
Hi,
I have changed my battery and i have a lot of problem...
First i have change the battery and i have a problem, the Touch Id doesn't work.
In Settings when i want to activate it, it's written "Fail".
I don't know why, because i have desassembly the phone without problem..
Few days later, i need to charged 3/4 times my iPhone per day and it's a new Battery ( very good quality buy here) and my External Speaker Doesn't Work...
What can i do ?
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 3
Комментарии:
Have you tried to restore from itunes?
из
Добавить комментарий
3 Ответов
Выбранное решение
You may have accidentally damaged some components during installation. Have you inspected the ribbon cables to see if there is any damage? It's always a good idea to go back through and make sure all the connections are clean and fully seated. You can clean them with isopropyl alcohol on a cotton swab, and make sure they're completely dry before you close up the phone again.
Does the home button click function still work?
Был ли этот ответ полезен?
Оценка 1
Комментарии:
Yes the home button Work, just the Touch ID and the external speaker doesn't work..
из
Download a programme on laptop called ibackup bot it will actually tell you how many times the battery has been charged..
Most new batterys you get are never original and have been charged I've 100 times unless you have a good supplier
Оценка 1
I had the same problem, found sensor cable was not seated fully. Took quiet a few goes to get it right.
Оценка 0
Добавьте свой ответ
robinphi58 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 165
