How to change sparkplug in Cadillac CTS 3.6 engine
changing sparkplugs what parts are required to be removed
Это хороший вопрос?
Это хороший вопрос?
You will have to remove the air filter hose that goes from the throttle body on the intake manifold and connect to the mass airflow sensor you have to unplug the throttle body you will have to remove the hoses that are connected to the side of the intake manifold you have to remove and take manifold just to get to plugs. But before start everything you will have to remove the safety bar first that goes from the passenger side of the car to the driver side of the car. Once you have removed everything you put the car back together the way you take it apart. I believe it's that 13 mm and a 10 mm is all you will need for this job.
Был ли этот ответ полезен?
За последние 24 часов: 7
За последние 7 дней: 14
За последние 30 дней: 39
За все время: 506
