How to change fuel filter 2007 jeep wrangler
Where is the fuel filter on my 2007 jeep wrangler JK and how to replace it?
Это хороший вопрос?
Это хороший вопрос?
fxdwg96pete, on your model there are two fuel filters being used. One at the bottom of the fuel pump module and the other inside the module. This Jeep does not use the older type that were mounted to the frame etc. It is also not necessary to replace the filters as part of a routine maintenance. You only change these in case of an engine diagnostics. i.e. OBD code. A separate frame mounted fuel filter is not used.
Был ли этот ответ полезен?
За последние 24часов: 12
За последние 7 дней: 47
За последние 30 дней: 141
За всё время: 24,482
2 Комментариев
We’re is in line fuel on a 07 Rubicon
из Darrell Mullins
How to determine her a bad Throttle body
из Darrell Mullins
