Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17вопросов Показать все
serial port damaged via 120 ac volts
i blew the serial port. is there any way i can repair or change it.
thanks
bill
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
BILL WESTON, it might help if you tell us how did you do that. Use these guides and take a look at the logic board. It is possible that you have extensive damage will be impossible to fix. Or it is possible that you only destroyed a few components. Hard to say without seeing it. Add some images of your damage with your question.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
BILL WESTON будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 102
