Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630вопросов Показать все
Front facing camera not working
I have 3 iPad Mini 1st gens with the same issue: The front facing camera is not working. I replaced the cameras and still had the same issues. Restored them to stock, same issues. Hard reset, same issues.
Has anyone ran into this before? I can't for the life of me figure out what the issue is. I checked everything out under the scope and the connectors are undamaged. Is there possibly a filter or something that could have popped?
HALP?
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Hey @joshw - what was the history on these? Did you get them resolved? If it were an iPhone I would suspect the camera LDO, but I have not ever seen this on a mini...
Cheers
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Never did figure it out. I checked every part on the camera circuit down to board level, replaced everything it was possible to replace, never could get them working.
There is no good reason why a screen swap would kill these camera but it happened. The only thing I can think of is if the camera IC somehow got fried but I can't imagine how replacing a screen could do that.
I chalked this one up to gremlins, looted the working parts out of these and sent the boards and cameras off to the junk pile in the sky.
из
Same problem. It is common...google it. The standard answer of factory reset and updating ios does nothing. I replaced camera itself with new part and still not working. This does seem to be a main board issue.
из
Why has my front camera cannot open? It is not working.
Оценка 0
Добавьте свой ответ
Josh W будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 2,450
