Rainbow colors after digitizer replacement.
My iPad was working perfectly except for the fact that the screen was cracked. I then proceeded to beat by a digitizer since the LCD seem to be working perfectly. I then removed the LCD and the digitizer at the same time. I then installed in the correct order. After turni my iPad was working perfectly except for the fact that the screen was cracked. I then proceeded to beat by a digitizer since the LCD seem to be working perfectly. I then removed the LCD and the digitizer at the same time. I then installed in the correct nag the iPad back on there is a rainbow colors all over the screen. Is there anyway to get my iPad back to normal or should I just consider the LCD crap and broken ?
Это хороший вопрос?
is it reversed colours? try settings/general/accessibility and change invert colours. you can also try tapping home button 3 times.
из pollytintop
