A series of external storage drives by Buffalo.
2вопросов Показать все
Buffalo Thunderbolt port broken but USB 3 works
This drive is out of warranty so my only option would be fixing it if possible. The drive is a Buffalo MiniStation Thunderbolt bus powered drive that also has USB 3.0. The thunderbolt stopped working yet the USB 3.0 works fine. I have two of these drives and the other currently works with thunderbolt. Is there any way to fix the thunderbolt port? Thanks
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
This guide is probably for an older model, but you didn't tell us exactly which one you have. It may help to be able to open it up and repair it: Disassembling Buffalo MiniStation External Hard Drive (Thunderbolt & USB 3)
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
This is the correct item. My drive is the 500GB one. What do I do with this to fix the problem once I get it open?
из
See if you find some obvious damage i.e. broken solder connection etc.
из
Наиболее полезный ответ
It depends on how it was broken. If the connector is loose, it could need re-soldering. If there is an onboard problem--due to heat, power outage, or any number of other factors--you may not be able to fix it without spare parts, replacement components, and/or a schematic.
My advice to you would be to contact the manufacturer. Even outside of warranty, you may find that you are able to get an out-of-warranty service or part replacement at a reasonable price.
Оценка 2
Добавьте свой ответ
Peter будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 1,059
