Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4756 Questions Показать все
Where is the temperature sensor on the iPhone 6
We had a iPhone 6 come into the shop today and we had to do a water cleaning on it. After cleaning, the phone turns on and seems functional. The only issue is the extreme temperature warning came on and won't go away. I'd like to replace the sensor but I don't know which part it is or if it's attached to the board. Any suggestions on where it is?
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 1
Комментарии:
did you replace the battery after you cleaned the logic board?
от
Yes, it would not turn on with the original one in it but it powered on with the new one. I also had to change out the screen on it too.
от
Добавить комментарий
Комплект инструментов для замены батареи Macbook
Доступно с $69.99
Buy Now
Доступно с $69.99
Buy Now
4 Ответов
Выбранное решение
First try a different battery, there is one in the battery.
Then it gets complicated, there are some NTC probes on the board, usually they won't break but they can be shorted causing false high temp. I don't have the layout so I don't know where for sure.
Был ли этот ответ полезен?
по рейтингу 1
Комментарии:
Thank you! I swapped the battery out with another one I had in stock and it worked immediately. That's the first time I had a battery do that to me
от
I found a schematic, if I shared the link would it help you to identify them? I'm having the exact same problem as OP.
от
Same problem. After contact with the liquid and replacing lcd connector this problem came. Probebly during replacing connector, temp sensor get shorted.
I used different baterys, please help. I found in diagram only ic U1602 but am not sure. Sorry for my ENG.
от
Наиболее полезный ответ
Check this solution,...
Change capacitor and resistor if damage
по рейтингу 2
Комментарии:
my problem was solved
thank you
от
Hi i have tried replace 2 new batteries, the problem is still there. I wonder where the sensor is? Probably the sensor is shorted? PLease advice, thank you.
по рейтингу 0
I'm having same problems. Did you finish a solution to yours?
по рейтингу 0
Комментарии:
Im Having same issue. Did you get your problem solver. If so what did you do
от
Добавьте свой ответ
Munkeyunk будет вечно благодарен.
Просмотр статистики:
За 24 часа: 2
За 7 дней: 44
За 30 дней: 219
За всё время: 24,359
