HELP: Power Supply broke from Motherboard
I was cleaning my PS4 for the first time in almost a year (out of country for work and PS4 was left behind to collect dust, unfortunately)
While putting it back together, I stumbled upon the horrible fact that I had accidentally ripped off the Power Supply from the Motherboard. I have absolutely NO IDEA what to do. If soldering is the solution, how much solder, and where? Any other Alternatives? A little chunk of the Motherboard came off, as well.
Any help, EXTREMELY APPRECIATED!
Это хороший вопрос?
16 Комментариев
Morgan Requiem add some clear images to your question. Use this guide Adding images to an existing question
из oldturkey03
Thanks for the tip!
I went ahead and added the images directly to the post.
из Morgan Requiem
I'm so !#^&@@ off the same thing happened to me now I'm afraid my system is destroyed
из Demetrius Powell
It's not destroyed...you can always send it in for repairs if you don't think you can fix it yourself.
из TronicsFix
Morgan I have the same problem can u help me with it
из PaulP84
Показать 11 больше комментариев
