Best tip to connect LCD flex cable without damage
Everyone,
What is your best tip to connect the LCD and digitizer flex cable connector to the motherboard, easily without DAMAGE nothing.
What is your best tip ?
Thanks
Это хороший вопрос?
Everyone,
Thanks
Это хороший вопрос?
With the battery unplugged. place the connector on top of where it should go. put your thumb on top of the connector, gently slide it back and forth, if there is resistant on all 4 sides that means the connector are in place and you can just push it down.
Был ли этот ответ полезен?
Thank you for your tip.
Any other tip :) ?
be gentle and try not to flick any capacitors off the board.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 284
