A budget companion phone for the Galaxy SIII, Also known as Samsung I8190 Galaxy S3 mini, Samsung Galaxy S III more. Available as Samsung I8190N Galaxy S III mini with NFC. Identifiable by the model number GT-i8190.
44вопросов Показать все
Why can't I get my phone to turn on?
My phone has failed to turn on or charge for a long time now, it looks ok, it has light white marks inside the back cover which may be water marks. The battery may be knackered, I'm not sure.
Это хороший вопрос?
Оценка 5
1 Комментарий:
Hi
I have a strange powering on problem too. My phone shuts off after using it for a few minutes won't turn back on without the charger. It can only be used constantly when charged.
Update: does not turn on at all, not even with a charger.
Replaced battery with a relatively new one from another phone (3 weeks) still doesn't turn on.
I would be most grateful for help.I'm desperate and I can't find any forum with this exact problem.
из
Добавить комментарий
2 Ответов
Hey Alex, this seems like it can be a faulty battery issue. You should get it replaced.
-Let me know if this helps.
-Please accept this as the answer if it answered the question.
Был ли этот ответ полезен?
Оценка 0
Hallo
A have the same problem, bud my battery is oke.
how can i replace the power button.
Andre
Оценка 0
Добавьте свой ответ
Alex Younger будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,381
