dell inspiron 15 3521 not charging
Это хороший вопрос?
Это хороший вопрос?
BALOCH SAEED, first you want to make sure that your AC adapter works properly. Use a multimeter to check the DC output and see what you get. If that is okay, you want to consider replacing the battery. If that still wont work, check the DC in jack. After that you will have to take a look at the logic board to verify that you have no burned out components etc. Use these guides to work on your computer.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 182
