Detach home button from ribbon cable
How do I detach the home button from the flex/ribbon cable?
Update
Thanks for the guide, but you se in the last image. How do I detach the button from the cable?
Это хороший вопрос?
Это хороший вопрос?
It is depends of your device, see the tear down section and follow the instruction until the home button removed.
If you not familiar with this friendly-UI website, you can use the search box at the upper right corner, just write the device you have, and the result contains everything (repair manuals, teardowns, questions, etc).
Был ли этот ответ полезен?
This is the closest guide we have for that process, but we do not have a guide for separating the home button from ribbon cable.
Oh, I'm sorry, i think he just want to detach the home button from the phone.
Is it possible though?
Possibility always exist.
But I'm no expert, Markus is.
Try asking him.
Hope this isn't too late but it is very much possible. Using a small flat head screw driver, I worked around and then underneath the mechanism away from the button. It's just a mild adhesive holding itself to the button.
Won't prying the button off the ribbon cable damage the cable? Can you add low heat to it first?
It's basically a sticker. Just work slowly and carefully.
I were mess it up when trying to detach the flex cable from the plastic home button. Now it does not work. Maybe it is broken somewhere.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4,576
