The HP 7 Plus 1302 runs the Android 4.2.2 Jelly-Bean operating system.
5вопросов Показать все
Why won't my HP 7 Plus turn on?
Hi, I’ve got an HP 7 Plus tablet and I can’t get it to turn on. It’s been on the charger for the last 8 hours and when I push the power button nothing happens. Can anyone help me get this thing working?
Это хороший вопрос?
Оценка 4
1 Комментарий
I tried unplugging the Hp 7 tablet battery and plugging it back in as recommended. IT CAME ON .THX . You rock!!!
из
Добавить комментарий
3 Ответов
Выбранное решение
Plug charger back into your device and let it charge for about ten minutes, Then hold down the power button until either the battery show on the screen or until it power back up. If the battery displays on the black screen that means your device doesn't have enough charge to power up.
If the problem is still not resolved refer to link below.
HP 7 Plus 1302 Troubleshooting
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
Take the battery out, hold the power button down for 60 seconds, put the battery back in. Then hold down the power button and it should start up. DONT have it plugged in when your doing all this. Hopefully that works for you!
Оценка 1
1 Комментарий:
How do you take the battery out?
из
i have a problem with my Hp 7 plus tablet when the first start and about the time to start automatically go to power off
Оценка 0
Добавьте свой ответ
Erik Hegg будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 1,324
