The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
My controller is lighten up but doesn't respond or work.
So I've got this controller ever since I opened the Xbox one box, so I joined a party to play CoD: Advanced Warfare but my batteries were low and my mic was plugged in and I didn't wanted my controller to turn off suddenly so I said why not plug in a USB wire so that It won't run out of batteries while playing, but then suddenly my mic stopped working but my controller is lighten up but for some reason not working, I pressed every button still nothing.. Help?
And thanks for taking your time to help me!
Это хороший вопрос?
Оценка 0
2 Комментариев
where did you plug it into?
из
It's like a samsung charger I plugged it from the console to the controller. (at the front of the controlller)
из
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
Usually smashing the controller against a fellow member of the houses head fixes it. It has something to do with a glitch in Microsofts sofware. Any more questions just ask. Signing off, PC MASTER RACE
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I REALLY appreciate this comment. I searched the web for 30 mins and kept finding syncing problems and not this. This fixed my problem! Thank you!!!!
из
To fix it for me I just restarted my Xbox and my controller started to work again, I hope this helps anyone coming looking for an answer too!
Оценка 1
what you do is unplug your xbox one for 30 seconds and if that doesn't work you must data wipe it
Оценка 0
1 Комментарий:
Cant data wipe it when i cant move my controller.
из
Добавьте свой ответ
Jake Fellows будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 10,072
