Is it possible to replace just the glass on the S6 Edge?
I cracked my glass within 3 weeks of buying my S6 Edge and I was wondering if there is a way to replace just the glass. Not to brag, but I'm a real techy guy and I've done other screen replacements in the past. I did a glass only repair on the s5, and from the pictures I've seen, the lcd is bendable on the edge. Will this still use LOCA glue and a UV light? I've got the tools, I'd just need to buy the parts. The glass is very cheap but the lcd and glass combo is over $200. Just wanting someone else's input before I go into something that could be way over my head. Thanks in advance! :)
Это хороший вопрос?
Yes, You can but be very careful not to use too much heat and don't puncture the battery!
I just replaced glass only on my 925t
Difficulty level; high..
из David Rudolph
If doing glass only why would you even be close to the battery!?
из Rob Blank
You can not get the glass off with out taking the battery out. It is a process. Don't we all wish it was that easy though. Just simply take the glass off lol.
из DERRICK CEDENO
Battery has to come out because of heating glass. Don't want to expose to too much heat
из T Payne
Can i do it in my s6 edge+ ? Where can i buy glass ? Thnx
из eurogoni
Показать 17 больше комментариев
