Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
1697вопросов Показать все
Controller won't sync with console.
I've run into an issue with a few PS4's where the controller won't sync with them. I know the controller I'm using is good because I've used it on several different PS4's without issue. Has anyone had any luck fixing this issue?
Thanks
Это хороший вопрос?
Оценка 2
2 Комментариев
When I plug the controller in and I press the PS button the light on the controller flashes blue, but it never connects. The light will go back to orange and then just repeats the process when I press the PS button again.
из
this is literally happening to me too but i am inexperienced with welding or whatever you guys do so i cant really fix this
из
Добавить комментарий
1 ответ
Выбранное решение
I managed to change the wireless communication chip on the motherboard and it fixed my problem. In this picture it is in the lower left hand corner covered by a white sticker and shield.
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
So you must have reballed it by hand?
из
I didn't even reball it actually. There are only about 60 contacts on the back of the chip and they are spaced far enough apart to not have to reball. I just fluxed the back of the chip that I took from another PS4, put it into position, heated it and it worked like a charm.
из
Wow..crazy...I assumed you would have to reball it. Nice! Hopefully it lasts a long time!
из
Soooo.....? Success??
из
how am i an inexperienced 14 year old gonna fix this
из
Добавьте свой ответ
RegencyTech будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 23
За последние 30 дней: 84
За всё время: 18,217
