The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
719вопросов Показать все
Вопрос закрыт
Why does an IPad 2 charging port not work after screen repair?
I did a screen repair. Then a customer a week later called me and said he was having charging problems after the repair. I just want to know if it is possible if a screen repair can cause that.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Did you have the dock connector disconnected from the logic board for any reason? Or maybe damaged the cable when removing the old glass?
Also possible that it's just a coincidence and the customer has a faulty charger or there is dirt in the dock connector.
Был ли этот ответ полезен?
Оценка 0
There are two pins that stick up from the charge to contact the back of the home button if one of these is broken off or bent that would cause it not to work also.
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 106
