Touch ID not working but home button working.
I repaired 2 different iphone 6 plus, Both had no problems with the repair everything works BUT the Touch ID. i did not rip anything and i done literally hundreds of these. BUT this past month 2 of the phones i worked on, the touch ID no longer works after. Much like if a wifi cable is ripped, the wifi option would be grayed out. that is the exact problem i am having with The touch ID, the option becomes gray, when i try to add a touch id it says that it failed almost instantly. I have tried a factory reset and restore, i also know a new cable will not solve it due to the fact that the home button is married to the board. I heard that apple can also reprogram it for you but i don't want to take that step. Is anyone else having this problem and know the solution to it?
Это хороший вопрос?
Have you checked the connector on the home button and made sure it is not damaged?
из James Soulsby
