will not turn on after having a power outage
my workforce will not power up after a power outage.
Это хороший вопрос?
Это хороший вопрос?
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
Был ли этот ответ полезен?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 5,062
1 Комментарий
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
из Tyler Momberger
