You must be very careful, its more complicated that it looks,
Go to YouTube, it will show you how,
There's 2 screens, ones a touch screen and then the monitor,
You must also remove the monitor, carful that you dont crack it,
Everything comes out, also be careful of the speaker wire it can snap off,
You must pry off the outer casing very slowly, remove all screws on the inside, there's only 2 maybe 3.
The monitor will be the hardest to come out,
The touch screen connects to the component sheet inside, careful not the bend or crack the wire connector, else you will need another touchscreen
Good luck
Be sure to watch the video on how too
Some dont have screws on the outside...
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
corrinestone, take a couple of high res images of all the sides of your tablet. Post them with your question by using this guide Adding images to an existing question That way we can see what you see.
из oldturkey03
