The SanDisk microSD card is a storage device/medium in the TransFlash/microSD format. The standard ones come in all different capacities, up to 2GB. It was released in October 2001.
14вопросов Показать все
Card Physically damaged (missing a chunk)and now corrupt- salvageable?
Hey everyone,
So a little over a year ago I found buried in the dirt a SanDisk MicroSD Card inside a MicroSD to SD adapter, I promptly forgot about it after failing to read it as an SD card with a camera. Today, I freed up the MicroSD card from the adapter to discover it slightly damaged, it's missing a chunk of plastic from a side, however, all the pins are still intact. I failed to read it with Android based readers, and am now wondering if there's a way I can repair it anyhow so it can be used. I was wondering if anyone can tell me if the part of plastic that's missing was an important part or if I can crop together a fix with some cheap materials.
Это хороший вопрос?
Оценка 7
Добавить комментарий
4 Ответов
Выбранное решение
i#ve looked at my micro sd cards. they have all a different circuit layout - but all of them have circuits in the area thats missing from your card.
i've tried to make a good picture of that circuits - but it's not possible with my magnifier (it#s just black in black) - but if you look on the backside, you can see the lines
i p'shopped a picture to show you the PCB (Printed Circuit Board) area on a micro sd card
Был ли этот ответ полезен?
Оценка 5
6 Комментариев:
Thanks for your answer- so it looks like it's not possible? What if I cut that area from another MicroSD card and soldered it?
из
no chance, i think you need the exact same card and a magnifier - then you would be able to see whats missing/damaged - but soldering anything to it is not possible - it's too tiny. i think that even painting with conductive silver would be impossible.
из
That's what I was thinking of, a coat of solder, like painting conductive silver (that would be much better). Though somehow I think that making the whole area conductive would screw up the circuits. Oh well, i guess its simply not repairable.
из
Good effort at repairing though! :)
из
great photoshop job there! looks as good as the stuff you see in magazines! :P
из
Показать 1 больше комментариев
TRY THIS!!! I am a stay at home mom and it worked for me. I bought a Caig circuit board pen from radioshack for $11.00 . I traced the path of the circuit cured in my oven. Be careful. And it worked. This pen is used as a repair tool by electronic companies but is available to the consumer. What would we do without Google!
Оценка 2
My mini sd hc 32 gb card sudenly not detected by my phone or pc. What can I do, Is it possibal to detect. Pl help.
Оценка 2
Try http://techrxgb.com they do data recovery.
Оценка 0
Добавьте свой ответ
rab777hp будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 29
За всё время: 18,184
