Try to fully charge the battery. Once you have done this on the AR Drone push the un-pair button then push the 'reset' button and place the AR Drone on a flat level surface and unplug the battery. On the iPod/device go to the WiFi menu tap on the AR Drone and select 'Forget this device'.
Reconnect the battery on the AR Drone and wait for the leds to go green.
Put your iPod into Airplane mode, switch on the WiFi and try to reconnect to the AR Drone.
If the led's on your AR Drone are green and you are still unable to connect can you try resetting your iPod/device .
You might have it on access-point mode, which is for Android users like me, i had the same problem and turned out it was on Ad-hoc mode, which is for Apple users. Hold down the unpair button for 5 sec. The LEDs flash red when access-point mode is switched to ad-hoc mode. The LEDs flash green when ad-hoc mode is switched to access-point mode
I've also read that wireless camera systems can interfere with the signal.
AR Drone help desk said that the all red on all 4 rotors means there's a problem on the main board.
hopefully you get them running again, Good Luck!
ΠΡΠ» Π»ΠΈ ΡΡΠΎΡ ΠΎΡΠ²Π΅Ρ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
ΠΡΠΎΠ³ΠΎΠ»ΠΎΡΠΎΠ²Π°Π»ΠΈ
ΠΡΠΌΠ΅Π½ΠΈΡΡ
ΠΡΠ΅Π½ΠΊΠ°
3
ΠΡΠΌΠ΅Π½Π°
ΠΡΠΎΠΊΡΡΡΠΈΡΠ΅ ΡΡΡ ΡΠ΅ΠΌΡ, ΡΡΠΎΠ±Ρ Π½Π°ΠΉΡΠΈ ΠΏΠΎΠ΄Ρ
ΠΎΠ΄ΡΡΠ΅Π΅ ΠΌΠ΅ΡΡΠΎ Π΄Π»Ρ ΡΡΠΎΠ³ΠΎ ΠΊΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΡ. ΠΠ°ΡΠ΅ΠΌ Π½Π°ΠΆΠΌΠΈΡΠ΅ Β«ΠΡΠΈΠΊΡΠ΅ΠΏΠΈΡΡ ΠΊΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠΉ ΠΊ ΡΡΠΎΠΌΡ ΡΠΎΠΎΠ±ΡΠ΅Π½ΠΈΡΒ», ΡΡΠΎΠ±Ρ ΠΏΠ΅ΡΠ΅ΠΌΠ΅ΡΡΠΈΡΡ Π΅Π³ΠΎ.
24 ΠΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
No wifi connection on my jxd 528 drone ..i use galaxy note FE..anyone can help to solve it?
ΠΈΠ· harry nugroho
Hello I was using Free fly 3 & I was making with thee setting & hit 24hz & 60hz then it say All I hit all & now no wifi signal
ΠΈΠ· Michael
Just reset the drone :)
ΠΈΠ· lpostoglu
Some one please answer that
ΠΈΠ· naiomi22
My drone doesn't have a rest button just a camera and the battery and on off switch.....
ΠΈΠ· Sean Simmons
ΠΠΎΠΊΠ°Π·Π°ΡΡ 19 Π±ΠΎΠ»ΡΡΠ΅ ΠΊΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
