Вопрос закрыт
Why does my gameboy mirco stop at the gameboy screen?
When I turn my gameboy mirco on it works like it normally would but it stays at the gameboy screen. I tried putting other games in and it does the same thing. What do I do?
Это хороший вопрос?
Оценка 0
2 Комментариев:
Does the interface between cartridges and the system appear to be damaged in any way?
из
are you sure there isnt a lose connection inside the unit
из
Добавить комментарий
2 Ответов
Did you check that nothing is blocking contacts inside the game-cartridge or in the Gameboy Micro? You can try a little bit of contact spray or to cleanse the contacts first with something like "Kontakt LR" or a similar product. Kontakt LR (www.crcind.com) has a brush included to be able to clean the contacts.
Был ли этот ответ полезен?
Оценка 0
Use a high percentage isopropyl alcohol to clean the contacts on the GameBoy and on the carts.
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,396
