4" smartphone manufactured by BLU Products, featuring a dual-core processor, 512 of RAM, and Android 4.0
Why is my phone screen stuck on "BLU"?
How do I fix my phone screen when its stuck on "BLU"?
Это хороший вопрос?
Счет 20
3 Комментариев
The phone stuck on blu logo
из
Mine was too, until I took off the plastic cover on the screen
из
I have the same issue is there a way to get my files before doin factory reset
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
try factory reset
Turn off your cell phone.
press and hold Volume Down + Menu button + Power button.
If you see menu of Recovery mode, then release your fingers from the phone.
now select "wipe data/factory reset" using Volume buttons to navigate, and Power button to choose.
Afterwards accept operation "Yes -- delete all user data".
select "reboot system now".
Done!
Remember you will lose all your files and data
Был ли этот ответ полезен?
Счет 3
13 Комментариев:
That didn't work my phone still looping
из
then you have to re flash the phone with stock firmware....
из
when i do that i don't see factory reset or wipe data
из
tell me what you see ... or a screen shot will be much helpful
из
I had to call and get mine replaced
из
Показать ещё 8 комментариев
It happen to me when my phone was stuck on the blu logo I flashed it and it was back to normal for a few day .It started happening again it stuck in the Blu logo and won't come on I guess flashing it hasent helped what else can I do ?
Счет 1
My phone is too, stuck on the Blu logo and I really upset, because I wish to use that phone but I can't boot it
Счет 1
It's probably just a glitch or your screen froze just power it off and let it cool down then turn it back on
Or if that doesn't work wait till it goes dead then charge it then see if it works then .
Счет 0
Добавьте свой ответ
Nevicki Milton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 32
За всё время: 13,518
